Upex
- Apr 12, 2012
- Location
- Norwich, UK
- 2001 s320 cdi w220 & 1998 slk 230 komp r170
All,
My S320 CDI (01 w220 pre face lift) was showing signs of a fading battery, so ordered a new one with higher ah and cca that arrived yesterday and was waiting for me when I got home.
Wire drive car off to work this morning, to ring me from 5 mins down the road having had the low voltage, bas, pas, airmatic (etc) warnings come up.
What luck I though, new battery just arrived, so I pop out and fit it. Car starts and the lock to lock steering method clears all the errors. I then went to work thinking all was well.
Gets a call from wife on her way home, car has done the same thing on her return leg but on the new battery this time and having done 20-30 miles fine. I dash out to find that the car won't even try to turn over.
I had to use the old battery that I removed in the morning to just get it started. Once running, all errors were back and lock to lock wouldn't clear them. Also, there were more errors including coolant, distronic, faulty display and maybe some others that I didn't catch and literally nothing worked, Windows moves a cm very slowly then stopped, no indicators, no Speedo, the whole dash blacked out, no headlights.
Left her run for 10 mins, and still no joy. Trying the lock to lock was very heavy on steering and when got to the locks, it's like they weren't there, just got stiffer and stiffer as I got closer to the ends, but no definitive stop as such.
After a little while I was able to get the very dim headlights on to limp her home. During this drive there was literally no go in her, 3k revs to even start to move off, very very slowly. No power anything, brakes, steering etc and she couldn't reverse 1 foot, just moved a couple of inches and stoped. I had to push back on the drive, which came just in time as the suspension had dropped to rock bottom then.
Does anyone have any idea on what's wrong or on how I can start to trouble shoot?
I did put a volt meter across the new battery when she was running and it showed about 7.3 volts (that was with the new battery but post stranding) but having taken the new battery out once home, it's at 10+v
Please help,
Upex
Please help,
Upex
