clk 270 55 plate glove box catch broke
alf1956
clk270 55 plate diesel
hello there ,i have a 55 plate clk 270 2 door & the plastic catch on the glove box has broke,does anybody know if if you can buy the catch without buying the whole glove box cover or if there is a repair that can be done|>
Pretty sure this used to be quite common, parts can be bought, just check that the latch part on the dash hasn't been pushed in so it doesn't latch properly, this can be adjusted.
thanks for your reply,its not an adjustment thing as the hook part of the latch has broken off so it needs a new latch.they are only thin plastic so thats probably why there are so many posts about the glove box.do you know where you can buy the latch part please ?
Mate did you ever fix the problem?
Cheers
does anybody know if you can remove the lid without having to take out the complete glove box? i thought if the lid came off seperate to the glove box it would be a lot easier to manufacture a fix for the broken catch
