Just a word of warning to fellow MB members and CLK owners, do not think it will be easy if your brakes are like mine, I found out the hard way today, seized and snapped bolts, corrosion, hours of hammering and drilling out of retaining bolts..what should've been an half hour job each side (front) ended up as a 6.5 hour job for the front pair, not helped by the torx bit snapping of in a seized disk retaining bolt (and too hard to drill out), absolute nightmare.
I think they must of been the original factory disks, 100k miles (and 10 years old) and the disks where completely seized on, the pads was easy. Oh and I spent an hour each side with a 4lb club hammer knocking the disks of their hub due to corrosion!... and yes all bolts/mating surfaes was soaked in WD 40 for a few hours before I started.
Seems like the previous owner swapped the pads regularly but never changed the disks (the outer flange on the worn disks had worn through the brake sensor wires above the embedded pad sensor itself triggering the OBD fault, the pads themselves where ok).
If anyone needs help if in the same situ, drop me a line.
