rowleyd3
Hi all,
Bit of a wierd question, but how do I get to a nut to tighten it up?!!!
Its the strut on the hood cover on a 2001 CLK Cab. I might have to be a bit more specific, as I'm not sure what its actually called !!!
When you lower the roof, the rear of the hood rises, then the cover opens. If you then stop the opening sequence - its the nearside strut on this cover that is loose, as the ball-jointed bottom goes through a hole, with presumably a nut on the reverse. Despite removing trim in the boot and under the cover, I can't see how to get to the nut on the other side of the plate - that tightens it at the bottom. There seems to be a void, but it appears sealed with spotwelds etc?
Apologies if its a bit of a ambiguous description, but I'm struggling to describe it any better !!
Thanks,
Darren.
Thanks,
Darren.
