CLK W209 270 CDI A/C not working!
JohnV270
CLK 270 W209
After i replaced the temperature sensor (the one under the radiator) and refilled with Freon the A/C worked and was blowing cold air but after ~1 hour or less of using the A/C, it started again to blow hot air through the vents. I also have the Stepper Motor Clicking Noise problem and haven’t solved it yet. But i think it's not because of the clicking noise, because my A/C wasn't working even before the clicking noise problem.
Interesting is the fact that sometimes when i turn on the AC and put it on LOW (digital clima control console) for 1-2 minutes it blows a little cold "breeze" just enough to make you think the problems is solved but then it blows again hot air.
What should i check next?
I diagnosed it with Star C4 6 months ago and that guys told me everything is ok...
Please help me.
Thank you.
You need to check the system pressure, if low then the compressor will not engage. Any garage should be able to test this for you or an A/C specialist. It sounds as if you have a leak somewhere.
Forgot to mention the fact that i did a presure test and everything is ok.
The problem is from elsewhere.
Problem solved. Presurse valve from compressor was burned.
