So the CLS has known issues... The V6 Cdi has issues... are they related??
Am I best sticking with my IL6 E320cdi as I've been looking at the newer things to swap it for...
Problem is greatly exaggerated. Both the old IL6 and the new V6 have been known to make a ticking noise. Only affects some engines and by no means all. Some find it annoying. Others don't mind. On the IL6 never really came up with a cure IIRC. Doesn't stop them doing mega miles.
But on the V6, on some engines, especially if running between walls with the window open you may hear an irregular ticking at low speeds. Or if walk round the front and listen carefully. Tick,tick, long space tick, space tick tick etc. Irregular in number and spacing.
According to Mercedes it is not technically a problem and won't stop the engine doing mega miles as usual. BUT if the owner complains and says the noise is annoying them then while under warranty they will change one of the main bearings that makes the tick. Out of warranty, they have changed all who have complained at my local dealer under goodwill for those servicing regularly with the dealer. And made contributions under goodwill to others. Important point is that it is a minor annoyance to some, and is only on some engines and does not harm longevity.
Mercedes have now changed the metal on the relevant bearing.
Just the 7g valve body issue that can affect any 7g mb.
So are you saying that as long as an owner (me?) isn't bothered too much by the ticking sound, a repair is not actually needed and the car can be used as normal, or at least until another fault arises?According to Mercedes it is not technically a problem and won't stop the engine doing mega miles as usual. BUT if the owner complains and says the noise is annoying them then while under warranty they will change one of the main bearings that makes the tick. Out of warranty, they have changed all who have complained at my local dealer under goodwill for those servicing regularly with the dealer. And made contributions under goodwill to others. Important point is that it is a minor annoyance to some, and is only on some engines and does not harm longevity.
Just bear in mind that a lot of the time independents were replacing valve bodies in response to complaints about jerky changes when all that was needed in many cases was a software update done free by any main dealer. When I bought my present ML350cdi it had jerky changes especially at low speeds and in low gears. Told my local MB dealer. They had it in and did the latest 7 speed update (last September) and since then it has been smooth as silk.
Thanks Hawk, this is a little light at the end of the tunnel...
steve333 said:^ I researched that engine before settling on the 500 Barry(really wanted a v8),couldn't find anything negative on internet searches just good owner feedback.
jaymanek said:Do remember that benzworld is an american forum and a lot of the problems are specific to those across the pond... Petrols are a lot more common over there and hence why more problems show up.
