Diesel Benz
Thank you
Yes I had to use DEV mode and by pass the nav drive installed option. Its simple if you can understand what the DAS options do. Although I configured the MOST ring in any random order and it makes no difference as everything works which I always find strange. I am also investigating how to fit a switched reverse camera, fitting and getting the image is easy, but not sure how to auto switch.
Do you know if firware can be downgraded?
I assume it maybe limited to the year of manufacture for the hardware. For example you cant install 2004 firmware on a 2007 NTG1 unit?
I find this message very confusing, perhaps you should clarify it a bit if you are still seeking for help. To me it looked like you teaching Alfie on how to use DAS, if you can do that, you would not need any help at all (and would know the answers to firmware downgrade question etc.).
I did not study the device you had installed but it sounds odd if you by-passed the Navi drive from DAS if you still need navigation.
![Confused :confused: :confused:](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f615.png)
