If the problem is as shown in the attached image then the solution was to replace the camshaft timing magnet as a unit. Basically what you can see in the middle of the picture with the loom connected. It has the (improved as far as I am aware) connector built into it which I believe is what causes the original problem.
Disconnect the wiring connector, remove the three allen bolts, remove the old magnet and install the new unit by reverse procedure.
I used an instant 'oil proof' gasket solution on the face of the new magnet before bolting it back on.
Since carrying out the above the area has had no further leaks and as you can imagine looks a lot cleaner than that now!
The item was not overly expensive which was a pleasant surprise.
Is this a pic of the new modified part or the old one as I'd like to have a look at mine and try and identify it.
