adam87
Cream Cloth W210 E Class Interior Valet
This isn't a 'How to' thread as I was was pushed for time on this one, but shows what you can achieve with with a few basic cleaning materials probably located somewhere in your home.
Henry the Hoover
Brushes
All Purpose Cleaner (I used Flash on this diluted about 4 - 1. Four parts water one part Flash)
Cloths
I think doing before and after shots will be better than showing the dirty ones then the clean ones.
You'd start by removing all the mats, then a good half hour to an hour just hoovering if it's bad like this one. Put the front seats right forward when doing the rear and right back when doing the front so you can gain access easily. Use a Detailing brush or small paint brush as a duster in one hand and the hoover in the other to suck up the dust flicked up from the brush. Basicly just go around everywhere dusting, vents, small trim gaps, seat seams etc...
Now there is no loose dirt in the car you can start to scrub the seats with your APC and a stiff-ish scrubbing brush. On light coloured interiors you need to clean/wet the whole seat so you don't get darker or lighter patches when dry. Once scrubbed wipe over with a clean dry cloth.
You can then wipe over and plastics and trim with your APC.
Pictures...
The seat belt bolt cover was removed to make life easier then put back on.
Henry the Hoover
Brushes
Cloths
Pictures...
