CabrioChap
- Jan 16, 2017
- A238 E350d 4Matic CABRIOLET 2018
You cant just 'code' the DAB module into the correct place. Its a physical ring order you need to get right. It really doesnt matter that much as the devices all work its just the error thats flagged up on the MOST ring thats all. That said I have once seen a car where the DAB didnt work properly until it was in the right place on the ring but generally it does work.
Ah, I didn't realise that MOST was only physical, I thought the fibre was just the transport and each module could be coded to have a logical address.
I think the factory location for the DAB tuner is in the boot under the spare wheel for the W207 Cabriolet I have, but as the wiring loom isn't in place, it made it easier for me to cable under the front footwell. I ran the fibre directly into the back of the Head Unit.
It was only when I removed the metal plate under the footwell carpet that I found a MOST connector there that I could have connected to.. hey ho.
I'm using the DAB screen antenna that came with the Dension DAB unit, I wasn't sure whether to amplify the antenna or not. I've decided to keep the +12v attached to the antenna for now.
I did buy the Mercedes FM DAB antenna module, thinking I could just replace one of the modules under the A-pillar trim and use the windscreen antenna, but that turned out not to be the case.
