I'm sure most of you are more careful. Just wanted to give everyone a heads up to be careful when defrosting your cars in the morning.
A few cars in my areas have been stolen with the keys inside. Remember, the insurers won't cover it!...
Buy A Volvo heating system has an electrical hot air blower that kicks in immediately then when the water circuit is warm it switches over to that. Instant demisting from freezing, although never sure why Volvo never fitted heated front screens when they were part of the Ford group![]()
So do all Mercedes diesels, don't they? I certainly get hot air within a few seconds in my E class.
Engine preheaters are good if fitted. Any energy used is offset by easier starting and less running a rich fuel mixture. Again quite a common fitment in mainland Europe a bit like snow tyres!![]()
ok, a bit worried, everyones saying their cars are toasty within 5 minutes but mine takes an age to warm up, could it be a stuck thermostat? or air in the cooling system, how do i check this?
Don't use the 'Auto' setting. Set temperature to highest setting, press 'Recirc' button and adjust fan to required level. Don't use the 'Recirc' button if your windows are misted up inside though, us A/C instead.
I find this is the quickest way of getting some heat into the cabin![]()
could it be that petrol cars warm up quicker?
Is that a fact, cause looks like most of us are doing it wrong..It is very difficult for the oil pump to move cold, thick engine oil when the engine is only idling. Hence, the generally held view is to start the engine and drive away immediately - especially in cold weather: the increased revs quickly deliver oil to the upper engine components (typically the camshaft and valve gear) and those engine revs also mean vastly more heat is generated by the engine block, too, which warms the oil quickly and makes it flow more fluidly.
As a matter of note, you should see that your MB auto box actually holds onto gears till much higher revs when the engine is cold before allowing an up-change to the next ratio specifically to accelerate the engine heating process.
I have to say I would never leave an engine idling on a cold day, the wear in the upper parts of the engine must be horrific.
what about magnatec technology?
how long does it take for the oil to come up?
what about turbo? keep it on for couple seconds to cool down before stoppin the engine? no
