BonzoDog
- Mar 16, 2005
- Location
- Luxembourg
- 280 cdi Break S211 Avantgarde, B200 CDI, W245, Autotronic
BTB 500 said:In Belgium on Friday we nearly got taken out by an airborne Golf estate which left it even later and tried to cut across the grass at about 80 mph . Unfortunately for them there was a ditch or something in the middle and the car took off. My OH watched the whole thing in horror (it was on her side - RHD car) ... I just saw it land in front of us, upright and spinning, in a cloud of water/steam/grass/etc.
We looked at the grass after subsequent junctions and quite often saw tyre tracks going across!
At risk of offending my many Belgian colleagues, the collective view among non-Belgies is that their driving could improve but it is maybe a Gallic/Latin thing, a spirit of Joie de vivre or maybe more joie de mort.
Belgies make the best Moules frites though and Moules season is only a few days off.
A few years ago I wrote an article for a local newspaper: Note that the local speed limit is 130 kph when dry and 110kph when wet.
Apologies if it is a bit long.
After 4 years of living in Luxembourg and driving in the slow lane, tucked in behind trucks, might I ask if I have worked out the local traffic rules correctly?
Roundabouts
The aim is to eventually have this anglo import banned.
Therefore it is important that no matter what would appear to be the sensible route through a roundabout, you should always drive around the outside, ignore any inner lane and at no time must you signal your intention, especially when exiting.
Entering the Autoroute.
When entering the autoroute you must completely ignore traffic conditions. On the slip road accelerate as hard as you can and put on the left hand indicator. As you reach the end of the slip road – marked by chevrons and a continuous line – cross the chevrons and immediately enter the left hand lane. It is best to conduct this manouevre without looking, as sometimes the volume, density and speed of surrounding traffic could be unnerving.
A special condition of this exists at Bertrange where the entry path is quite short. If you lose your nerve, stop at the end of this lane with your left indicator on and your car positioned partly in the autoroute.
Exiting the Autoroute.
Maintain your speed and position in the left hand lane and when you are parallel with the chevrons that indicate the end of the exit lane, move quickly right into the exit lane. If you lose your nerve, stop in the left hand lane until a suitable gap appears.
On entering the curve maintain the foot on the throttle and rely on your stability control system to get you out of trouble. These exits (and sometimes entry lanes) become tighter once you have entered them and are a real test for these electronic controls on your cars. The best ones are at Kirchberg and Senningerberg
Speed Limits
Speed limits are for guidance and on main roads and autoroutes you should add at least 20 kph to the limit. An advised speed on the autoroute is 150 to 160 kph. driving at 110kph in the wet is for wimps.
Driving on the Autoroute
Use the car in front as a guide and attempt to maintain a distance of no less than 2 metres
Use of Indicators
The indicator is only to be used on the autoroute and must be left on, indicating left, at all times.
Use of throttle and brakes.
The right foot is to be placed hard down on either the throttle or brake. For example, if you see that the traffic ahead of you has halted, either at a traffic light or a traffic jam, keep your right foot hard on the accelerator until the last possible split second when it should be applied as hard as possible to the brake. The aim is to stop suddenly within one metre of the car in front.
Trucks,
Trucks are slow and driven by professionals. They will rarely lose their patience even under the worst provocation and therefore you can treat them with contempt. Even though the mathematics of trying to stop 38 tonnes is frightening when viewed against a lightweight 3 Series or Megane.
