SavMan
Simon - your numbers are exactly where they should be. Kleemann will quote you 550hp with a pulley, map & filters
Simon - your numbers are exactly where they should be. Kleemann will quote you 550hp with a pulley, map & filters![]()
They look good, I would not change them unless you can log your AFR's while on the road. Next time you are in a dyno also ask for IAT's and Boost (if its forced induction) and make sure they are running a 55K in 3rd gear.
Hi Paul, my last dyno run was done in 4th gear....why would you recommend 3rd?
4th gear is a much longer pull than a 3rd gear pull, this creates heat. To much and you end up with fuel dump and timing pulled, the result can be less power and a curve which dips or flattens at higher RPM and rich AFR's
Alps - Billy has changed his belt which I think I will do too. Not expensive either, order from amazon US, its a Gates K080496HD V-belt about $34 plus postage.
You achieved good bhp on your last run at SRR, out of interest what was your torque figure like?
You can also get the belt I did from most motor factors, it is not as small as the Gates belt, but smaller than standard, see comment below from another thread...
The Gates 496HD is a popular choice on the US forums, so must be good. Most comment that the standard belt size is fine as the tensioner if functioning properly, should be able to take up the slack created by adding the smaller pulley.
The standard belt is 1289mm (507.5 in Gates and some other belt manufacturers reference or 50.75 inches), the one you have fitted is 1260mm (Gates 496 x 2.54, or 49.6 inches), I also decided to fit a slightly tighter belt but went for a Continental Contitech 8PK1275 (502 or 50.2 inches). I asked Jerry when he was over and he said that the standard belt should be fine.
Jules.
Hi Jules
The one from the states seems to have been made from an alternative material, as for the standard belt being fine, I have to disagree some of the problems I was having Jerry said "belt Slip" so I changed it and for the sake of a few ££ why not just get the belt that others swear by? I mean my car runs great now, don't lose the power mid range, I know from my own experience standard belt with a smaller pulley is no good, even with a new tensioner. I recommend anyone fitting a smaller pulley fit the recommended USA Green back belt, perhaps the guys that stock the pulleys can get the belts in stock..
I agree, the pulley is dimensionally smaller so needs a smaller belt. I bought a smaller belt to put on with the new pulley but was told the std belt would be fine unless worn. This was at the EC day, I asked Jerry and he said the same, but I fitted it anyway as I am not confident my tensioner is 100%.
Jules
I say to anyone considering tuning, do the basics 1st
Billy, I think we are agreeing. Like I said, regardless of what was said on the US Forums, who have much more knowledge than us, I still thought it wise to fit a smaller belt along with the smaller pulley. It was other's with more experience than me that said it wasn't necessary. However, if there is something that is failing mechanically or if the power being called for is high then this can cause belt slip on the standard belt....for sure. My point is I would fit the smaller one anyway as dimensionally it just makes sense.
Not disputing what you say about getting the basics of maintenance right....you are spot on to do this and advise others as well.
I'll get mine on a dyno soon and see what it puts out, but as it is on the original EC map (not been revised since the EC day) then I am guessing nearer 550bhp.
Jules.
Hi billy if watford isnt too far. I have a guy who would be able to do the car and also log the IAT's while running the car.
Well, have been to SRR this afternoon and the car did ok, keeping it in line with the others on here and the respective mods. Will post the graph later.
Jules
Jules
simon1966 said:Jules
Will be interested to see your results. Shame we went a day apart as we could have met up yesterday.
Simon
