Thanks for your tips - some good stuff there. I'm working on sourcing the underlay but will try a revised mount first to see what vibrates. I've got a small rectangle of Dynamat left (it has lasted me 13 years for a roll so far!).
Sounds look a job well done. Amazing how little power you need for IB. Can't wait for the pics.
Aye, a job very well done EIISSM. Having OCD and perfectionism issues means I spent a lot longer but I want it to sound the very best it can.
No, the amount of power required surprised me a lot (my amp is only 350w RMS continuous). Even at low levels to avoid the "woofer slap" as I call it, you can definitely hear the lower order which was missing before - without it being 'in your face'. I cannot believe how much the cone moves and I did question the amount of space I'd left but thought it wouldn't be moving a lot...
Don't go thinking the install looks like the one SavMan posted of his son's Clio the other day! It's very neat and functional, but in no way "object d'art'!
Nick, he's not independently amplifying his front speakers, just running from the AGW, so will be stuck with the internal cross over points. But as a side note, i was led to believe that the cross over points should be set the other way round so as when they overlap (approx 100hz) there is no bump in the level. Would be interested to hear your view on this as someone who is better qualified than most forum goers?
For a long time I have had my sub on a 50hz LPF and my fronts on a 75-80hz hi pass. Have been meaning to get it on an RTA to see what's going on, but it doesn't sound too bad to the ear.
I could still add a capacitor of LPF (but would need to be after the tweeter feed in the doors) for the remaining channels as full range is going to them (I imagine the tweeters have built in capacitance).
I've got my LPF on the sub amp running at 50Hz and the gain / boost controls on about 2/3s.
This system is slightly unusual as said previously - because I am not binning the whole lot and starting again, I have a situation where the system I had before, with the bass control up fairly high, I had a fantastic sound to my ear, but just missing the very low levels and they clipped early (it took me 16 months before I realised it had no sub!).
Now I am in a position where I can bring down the bass level on the head unit, and increase the sub volume, to bring in the lowest levels and give the stock woofers less work to do (and avoid clipping of course) - probably without the need for an HPF.
I really don't have my system at loud levels at all and the stock system before I did anything got to a level which is too loud for me (albeit with clipping on certain songs) - so I really didn't have much work to do to get it how I wanted it...
I have some more MDF now so this weekend is highly likely for completion. I also produced some cardboard 'gaskets' to bridge the MDF and the metal body - these work really well but I will make some new ones as I made the first lot quite roughly. I can't think of a better way because the shelf is not flat as said. Anything permanent (like sealant) will be a pain if I have to take it off (again) for any reason e.g. the woofer develops a fault or something.
