driver2000
- Feb 11, 2009
I have a GL420 CDI (bought new; 20months old, 20k miles; no off-road use; typical mixture of town and dual-carriage way driving). I was driving on a country lane at around 30mph. On reducing speed to about 20 mph and turning on a tight bend the steering suddenly locked and the engine cut-out. I managed to bring the car to a halt. Engaging park, I was easily able to restart the car and drive home normally (about 5 miles).
Has anyone experienced this? What could the cause be?
Fortunately there were no other cars around at the time otherwise there might have been a serious collision. MB accepted that the car should be recovered to the dealership rather than be driven there by me.
I posted this query on the US MB forum and got a number of replies. It is a bit disconcerting that a number of drivers have had similar experiences. I get the impression that the crankshaft sensor recall was for diesels only, yet the problem has occurred on the petrol models. Someone suggested it was an ECU crash. Someone wondered whether I had knocked the ignition key - but it was still in position 2 when the engine cut-out.
The car is still at the dealership. So far they haven't found anything; the ECU has had the latest software upgrades. They've done a road test with diagnostics and haven’t found anything. I put it to them that the crankshaft sensor might still be faulty but their view is that the crankshaft sensor problem not only cuts out the engine but prevents the car from being started. Right now I don’t accept that view as the recall letter makes it clear that you might be able to start the engine.
By the way, apart from this problem I think the GL is a great car. For 7 seat comfort it trounces the Audi Q7, Volvo XC90.
(For your information here are the other issues I have had with the car, some of which I think other owners have mentioned on the US forum.:
1) Intermittent 'oil level too high' warning. Incidence reduced after software upgrade but it still happens sometimes, usually after driving for some time at over 60mph
2) 'top up coolant' warning. Cured after software upgrade
3) Urgent safety recall P117- to replace crankshaft sensor which, MB quote, ‘an electrical discontinuity in the crankshaft sensor could occur under unfavorable circumstances. If this problem occurred, the engine would loose power. It could also be no longer possible to start your vehicle.’. Work completed in December 2008
4) Auto gearbox control unit problem in January 2009. Symptom was the gearbox stuck in D2. Fixed when gear box control unit replaced.)
