Hi Pat, if it is only the supercharger pulley noisy? dont buy the complete double pulley arrangement because you can fit a new bearing in the metal pulley for the supercharger, i have a spare bearing that you can have for £10.00 including post, cheers Dave
Sorry Pat, i am confusing the issue i meant the Supercharger Idler pulley, cheers Dave
same thing happened when i removed the very same bolt the first time, killed x 3 torq bits and then rounded. sourced a bolt from the states! It didnt have any additional loctite, just what was from factory, no idea why they tighten up so much.
the ASP pulleys are made to replace bearings hence i had them put in , been a efw years so probably right timing
Hi Pat, If you get stuck ive got some new 6203/c3 bearings, and a very good condition Tensioner complete with standard pulley, if you want to convert back to standard pulleys i have the other tensioner too for the auxillary belt? think ive found a bolt that should do if you want it?
An impact gun works wonders on these bolts. I have changed a number of my pulleys a few months ago.
I used the following NTN bearing to replace the OEM NTN one.
NTN Bearing 6000 - 6200 - 6300 Series - 2RS - ZZ - *Choose your size* | eBay
