First full C63 AMG front & rear brakes BBK retrofit to w204 with only original parts
perdikoyla888
First full C63 AMG front & rear brakes BBK retrofit to normal w204 with only original parts
Everything fits perfect and performs excellent!! :bannana:
I have just completed a full C63 AMG front & rear brakes BBK retrofit to my non-c63 w204. I am posting some photos and I have compiled a complete list of the parts used. Everything original MB OEM parts. No aftermarket parts and taiwanese brackets. I think this is the first retrofit ever attempted with no aftermarket parts at all. I hope this helps!!! :)
FRONT BRAKES
A2044214798 x1 CALIPER - PARTS KIT, LEFT
A2044214898 x1 CALIPER - PARTS KIT, RIGHT
A0004214765 x2 BLEEDER VALVE - WITH DUST CAP
A0014210991 x2 SPRING
A0004215174 x2 TS BOLTS PARTS KIT
A2214210014 x2 PULL ROD
A0169900601 x2 BOLT
A0044208920 x1 BRAKE LINING/TS DISK BRAKE PAD - PARTS KIT
A0019900814 x4 BOLT - CALIPER TO STEERING KNUCKLE M14x32
A1715400617 x1 BRAKE WEAR SENSOR - BRAKE LINING WEAR INDICATOR
A2194210212 (or A2124210512) x2 BRAKE DISC - FRONT
A2044211320 x1 PROTECTIVE PLATE - LEFT
A2044211420 x1 PROTECTIVE PLATE - RIGHT
A2094280135 x2 BRAKE HOSE - FRONT LEFT AND RIGHT
A2043321901 x1 STEERING KNUCKLE - LEFT
A2043322001 x1 STEERING KNUCKLE - RIGHT
A2043220122 x2 PIVOT PIN
A2119810227 x2 ANGULAR CONTACT BEARING
A2113570508 x2 FLANGE
A1403570572 x2 NUT
A0019904203 x8 BOLT - BEARING AT STEERING KNUCKLE
A2113331114 x2 BEARING - STRUT
A2043304911 x1 CROSS STRUT - LEFT
A2043304911 x1 CROSS STRUT - RIGHT
A2045401817 x2 SENSOR - RPM SENSOR, FRONT
A2044013902/B66030098 x2 DISC WHEEL-5SPOKE WHEEL FRONT AXLE 8Jx18 H2 ET45
A0035400217 x2 (optional) TIRE PRESSURE SENSOR - TPMS CHECK 433.92MHZ
REAR BRAKES
A2044234198 x1 CALIPER - PARTS SET, LEFT
A2044234298 x1 CALIPER - PARTS SET, RIGHT
A0014210791 x2 SPRING
A0004214274 x2 PIN - PARTS KIT
A0189900001 x4 BOLT - CALIPER TO WHEEL BEARING
A0054202520 x BRAKE LINING/TS DISK BRAKE PAD - PARTS KIT
A1715400617 x1 BRAKE WEAR SENSON - BRAKE LINE WEAR INDICATOR
A2044230412 x2 BRAKE DISC - REAR
A2044014002/B66030099 x2 DISC WHEEL-5SPOKE WHEEL FRONT AXLE 9Jx18 H2 ET54
more photos 1:
Congratulations, that looks great. So I see you've moved on from your W203.
Have you done many other mods on your 204?
more photos 2:
I am doing more mods slowly, I have already bought parts for my next mods. Until now I have installed rear spoiler, rear diffuser and under heatshields to install the original c63 exhaust. Also installed tpms sensors to the wheels.
how much did you have to cash out?
I bet this was an expensive mod!
Did you use brand new parts or used parts?
Can C63 calipers be bolted on the original 334mm C43 rotor?
I dont think c63 caliper can be bolted to c43 as it is a different offset and also mounting points are different. I used brand new parts as the car is new and do not want to void warranty.
Looking good. Well done:) I bet they weigh a bit though!
now you have to begin to save money for a real C63 without brakes!:D
now that you have this standard c-class, when you get the c63 without brakes just swap them.:rock:
That`s a very nice upgrade and expensive to,i like it but i would lose that blue-efiency
What engines in your C-class?
great conversion but not sure of its benifits / costs depends what plans you have for the rest of the car I guess.
I have used the P30/P31 performance two-compound brakes that are lighweight for performance purposes. I assume lightweight is bue efficiency as well. :)
I never fancied a 6.3 litre engine. My engine size is just perfect for me and my driving habbits. When it comes to petrol, insurance, taxes and personal needs & circumstances my car is a better choice and winner especially this period that european crisis has affected every sector of the economy. :bannana:
I thought you had a future goal?
Maybe one day you were going to buy the AMG and for now were only dreaming of the desired C63?
I bet it's costly to own muscle cars in the UK?
Downsizing is the way to go nowadays!
I would love to drive a c63 but I would not like to own one. I could have bought a c63 but it is not wise for my needs. However I am sure that I will end up spending more money to make my w204 the way I like it, much more money than what I would have spent to buy a c63. I know this from my previous experience of fully modifying my w203. ;)
But I agree with you that a c63 is a real monster with raw power under its hood.
I am attaching some photos of the end result. :)
continued 2:
continued 3:
Nice conversion :thumb:
Just a thought - have you informed your insurance company? If so did they charge you any extra premium?
FRONT BRAKES
A0169900601 x2 BOLT
A1403570572 x2 NUT
REAR BRAKES
I have a 2012 c350 and quite interested in this mod. What brackets did you use for the front calipers?
