found a great Code reader / fault clearer
Herishi
2007 E280 Sport
Guys
I got my first mercedes a few months ago and I have spent a lot of time on the forum, however most of my time has been spent taking from the forum rather than giving to the forum, so its pay back time :-)
I found an OBD2 diagnostic tool that seems to bridge the gap between the normal OBD tools and Star diagnostics.
I saw a post about an app called MerceWhat and it looked good, it is free to download and test, you then email the app designer a log file and the decode it and reply with the full diagnostic report.
I was impressed with the emailled report below as it picked up on a lot of faults that a professional OBD tool didnt!
I had previously used a Sealey dedicated diagnostic tool and cleared all faults before receiving the below report.
BASE: Series 211 - E Notchback/Van / Baureihe 211 - E Stufenheck/Kombi
BUILD-YEAR: 2007
MODEL: all/alle (-)
FAULTS: 12
ECUs: 32
BATTERY: 11.9V
DEPTH: Enhanced communication
SPEED: fast
CONNECT: Fast Connection
VERSION: 9.0
DEVICE: >iPhone< >iPhone OS<
WIFI: >WiFi_OBDII<
ELM: ><
COM+: >UNKNOWN<
0. Motor Control:
ME - Motor/Engine Electronics (HW: 0044465340 , 89):
- ECU OK, no fault code
FSCU - Fuel pump (-, 242):
- ECU not present/no answer
1. ABS / DSC / Brake:
DTR - Distronic (-, 52):
WSS - Weight sensing system (-, 773):
2. Airbag:
AB - Airbag (HW: 2118702626 , 46):
3. Transmission Control:
ETC - Electronic transmission control (HW: 0034460310 , 161):
ESM - Electronic selector module (HW: 2115454432 , 207):
4. Instrumentation:
OCP - Overhead control panel (HW: 2118207101 , 111):
IC - Instrument cluster (HW: 2115406548 , 341):
UCP - Upper control panel (HW: 2118219579 , 454):
- Fault: The folding switch panel received no authorization to open or close from the AGW, CD changer, COMAND or audio systems.
- Code: 009033
RWT - Rear-end door control module (HW: 2118705626 , 546):
LCP - Lower control panel (HW: 2118216958 , 738):
5. Light/Rain Control:
HRA - Headlamp range adjustment (-, 21):
XALWA-L - Xenon headlamp, left (HW: 01150002FF , 778):
XALWA-R - Xenon headlamp, right (HW: 01150002FF , 779):
6. Heating / AC:
AAC - Automatic air conditioning (HW: 2118302090 , 352):
- Fault: A32n1 (Blower regulator) / Overload shutdown If no customer complaint exists, the fault can be erased.
- Code: 009465
- Fault: Not Relevant! A32n1 (Blower regulator) If no customer complaint exists, the fault can be erased.
- Code: 009460
- : Sorry, there is no explanation available
- Code: 00001C
- Fault: R22/3 (Heater booster) ( Electrical fault )
- Code: 009470
STH - Stationary heater with remote control (-, 661):
7. Immobilizer System:
ASSYST Active Service System (HW: 2115408345 , 766):
ASSYST PLUS - PLUS Active Service System (HW: 2115408345 , 771):
8. Park distance control / PDC:
PTS - Parktronic system (HW: 2115458932 , 495):
- Fault: A42b4 (Right inner sensor, front bumper) : Sensor is faulty.
- Code: 00900A
9. Audio / Navigation / Communication:
CTEL - Cellular telephone (-, 77):
DAB - Digital radio (-, 104):
COMAND or AUDIO (-, 290):
SDAR - Satellite radio (-, 592):
SOUND - Sound system (HW: 2118701885 , 629):
TV - TV tuner (-, 734):
UCI - Media Interface (-, 740):
AGW - Audio gateway (MOST network management, diagnosis gateway, radio tuner) (HW: 2118702889 , 776):
- : Fault: CD / DVD : Error while reading the CD If no customer complaint exists, the fault can be erased.
- Code: 00D243
- Fault: Not Relevant! The wake-up line has Short circuit to positive.
- Code: 00D136
TELE AID - Telematic service Emergency call (-, 795):
TELE AID - Telematic services Remote door unlocking , Remote door locking (-, 796):
TELE AID - Telematic services MB Info , Roadside assistance ( USA, Canada ), Tele diagnosis ( ECE ) (-, 797):
TELE AID - Telematic service Stolen vehicle tracking (-, 798):
10. Systems:
AHE - Trailer recognition (-, 2):
LAE [LAA] - Loading floor automatically extendable (-, 20):
BCM - Battery control module (-, 73):
EZS - Electronic ignition switch (-, 215):
HSW - Heated steering wheel (-, 369):
SCM [MRM] - Steering column module (HW: 1715450532 , 434):
MSS - Special vehicle multifunction control module (-, 441):
TPC - Tire pressure monitor (-, 526):
Pass-side SAM - Passenger-side signal acquisition and actuation module (HW: 2115455332 , 548):
REAR SAM - Rear signal acquisition and actuation module (HW: 2115455601 , 560):
- Fault: Circuit 30 has an undervoltage of < 10.5 V. This fault is mainly listed when the engine is started. Low voltage only occurs when the fault is erased after engine is started and then appears again.
- Code: 009039
Dr-side SAM - Driver signal acquisition and actuation module (HW: 2115457401 , 572):
- Fault: Component E5/1 (Left fog lamp is faulty or the lead has open circuit. Component E5/2 (Right fog lamp) is faulty or the lead has open circuit.
- Code: 009005
ESP - Electronic stability program (HW: 0365457532 , 574):
System diagnosis (HW: 2115408345 , 587):
GPS box (-, 791):
CGW - Central gateway (HW: 2115408345 , 813):
11. Chassis:
ENR - Electronic rear axle level control (HW: 2515450216 , 168):
12. Body:
ARWT - Automatic rear-end door / RWTS - Rear-end door closing (-, 56):
DS-LF - Left front dynamic seat (-, 228):
DS-RF - Right front dynamic seat (-, 231):
DSP - Pneumatic pump for dynamic seat (-, 472):
RevETR-LF - Left front reversible emergency tensioning retractor (HW: 2118271145 , 535):
RevETR-RF - Right front reversible emergency tensioning retractor (HW: 2118271245 , 538):
HS - Seat heater (-, 612):
ESA passenger - Electric seat adjustment front passenger (with memory) (-, 639):
ESA driver - Electric seat adjustment driver (with memory) (-, 643):
DCM-RL - Door control module rear left (HW: 2118704026 , 693):
DCM-RR - Door control module rear right (HW: 2118704126 , 698):
DCM-FL - Door control module front left (HW: 2118707326 , 708):
- Fault: There is a discontinuity in the line to component M21/1r1 (Mirror heater) or the component is defective.
- Code: 009211
DCM-FR - Door control module front right (HW: 2118707226 , 717):
- Fault: There is a discontinuity in the line to component E6/6 (Right exterior mirror turn signal lamp) or the component is defective.
- Code: 00920B
13. Motor Control:
Screen shots of the screens before testing
more screen shots before diagnostics
last of the pre diag screen shots
I dont have all the options that the scanner can check so my report after the scan was less comprehensive that it would be for others
3 screens shown attached
All my tests were on my 2007 S211 280 sport, I dont work for the company that made the app and the activation cost me £29.99 (full price)
Looks good. Would be interested to see what it shows when a fault is found and how it is cleared.
The bridged gap you refer to in your original post is still along way off Star but does look like it can carry out more detailed information than your everyday readers ;)
Yeah I don't think it comes close to star but I've never used star. When I first plugged in after receiving the report the pics of the results just showed a yellow arrow. When you clicked on it you got the fault description that was written in the report. If anyone can think of an easy fault to put on I'll get a screen shot but I am very impressed.
Error 1
Error 2
@merc350cdi this is the one I've used
very similar to BMWWhat app, i have another wifi adpater, can i load the MerceWhat on and where to get?
I downloaded from the apple App Store. I searched for ivini (the people that make it)
