JohnnyW202
- May 22, 2011
- 2004 Mercedes E270CDI Elegance Saloon, 2004 C200 Kompressor Estate Avantgarde SE Sport Pack
Hello gents.
Upon inspecting my recent abs sensor problem I noticed that the reading kept falling to 2km/h every few seconds and setting the abs esp defective codes. Code was front right speed sensor visually inspect component.
Pulled the hub and noticed the rear seal is missing rubber. Is this rear rubber seal the abs ring I've heard it's magnetic.
I've seen replacement rear seals for £10 will this likely fix my problem the bearing and hub are perfect just the abs problem.
Front Axle Shaft Wheel Bearing Seal Fits MERCEDES W212 S212 1.8-5.5L 2001- | eBay
