Thanks very much,For a warm engine (coolant=80°C) at sea level, with and without A/C consumption is approximately:
2.2 4 cyl AC on: 0.86 Litres per hour
2.2 4 cyl AC off: 0.49 Litres per hour
2.7 5 cyl AC on: 0.62 Litres per hour
2.7 5 cyl AC off: 1.08 Litres per hour
divide by 4.54 to get gallons per hour.
Had my laptop plugged into a Sprinter this afternoon and the figures are spot on.
Regards
Matt
Thanks very much,
I'm a bit on the slow side, but does that equate to a pint an hour? 1.03?
I think I'll chuck my engine in a boat Although knowing my luck it will be 8 gallons an hour
Regards
John
Mercedes Actros trucks actually show the GPH on idle.
Nearer 2 pints per hour. A litre is greater volume that a pint.
1 litre = 1.759 753 986 pint [UK]
No messing about with litres or pints there....not enough digits in the display.
So 1.08 l/h = 1.899 pints /h.
Oi,So 1.08 l/h = 1.899 pints /h.
Correct.
I learnt it at school just a 1ltr = 1 3/4 pints. Can't be bothered with the other numbers.
Just noticed though, buy the 2.7 5cyl.
It's cheaper to run with the A/C on
