fuse box map e class w211 engine bay
tuc2904
Belfast
Mercedes e270
any one have a fuse box map for 2003 e class w211 (engine compartment) thanks.
fuse box in engine bay..... fuse location f59 which is 20amp which has blown, my prob being car wont turn over battery voltage reading 11.8v on dash dropping to 10.4v when ignition turned on, try to start car and nothing happens at all.... not even a click.... battery out of car and on charge atm, so im wondering if this fuse is the one for starter trigger.... thanks
ok thanks for your reply... ill have a look at that replace and refit battery and let you know if this cures my problem.. thankyou.
Car sorted...... cant belive it turned out to be a blown fuse in engine compartment F59 20amp replaced and turned over straight away........ thanks for the help and suggestions.
