gearbox, sticking, cl500, 1997
lunarboy
Gearbox (auto) appears to be sticking in 2nd - what can I do/ try? It will still go and will de select and can move into reverse but once d engaged seems to stay in 2nd. even manual selection doesn't over ride :dk:
have u checked gearbox oil level in other models this happens if low on gearbox oil it just a thought
If it doesn't go above second gear at all it is in limp mode. There is something wrong and the car is not letting you drive it past a certain point to prevent damage.
The car needs to be put on STAR. Where abouts are you located? I may be able to recommend a specialist near by.
sticking gearbox
I have been told to contact Alan Mills in Carluke - lanarkshire, scotland.
It still delivers plenty of speed but only in second, it also felt like it slipped when I engaged D at the traffic lights.
I will get it on the diagnostics !! thanks:confused:
