Well, having picked up my new motor and having had it a week, heres some pictures and early thoughts.....
Mid-corner bumps.....
Chassis
I thought I'd start on my 'first-impressions-after-one-week' by commenting on this cars most impressive dynamic feature.
You know the scenario....you're going round a bend fast, the car is under load and you hit a deeply sunken grid half way round. What's then always happened in my experience was dependent on the car.....the Porsche was largely the best with a steering column that would absorb the bump and give away just a slight movement in steering wheel angle. However, even in the Porsche, you'd feel a shudder, a vibration, some kind of movement through the column which would give you reason to very slightly grit your teeth.
Even the standard XKR that wowed me a few weeks ago had a little of that trait but was tight enough for it to still feel extremely robust in this situation - it was at the very least as good as the Porsche in that respect.
But, and you know where is going don't you....my Jaaaaaaag doesn't. The first time I went over such a grid in it (on a road I know very well so thought I knew what to expect), and found that the car didn't flinch, the steering wheel remained where I pointed it and the column was rock solid, I got so excited I nearly punched my other half sat next to me! I have never felt a structure so stiff and so capable of dealing with 'our' type of roads so well.
The reason for the difference between the two XKR's is that mine has the optional 'dynamic pack' .....an option that I've got to admit I was a bit nervous about. I wondered if it'd spoil the nature of the car like Clarkson said about the XKR-S (the 'dynamic pack' is the XKR-S chassis). Well, as I drove it away from the dealer for the first time, I did notice that it's extremely stiff....for a Jaaaaaaag. It's noticeably firmer than the normal XKR but, having say that, it's not even the teeniest little bit uncomfortable...indeed, the car still has a little bit of roll but you'd only notice this against a really hardcore sports car like a 911 or GT-R, both of which the Jag comfortably outrides despite the firmer set-up. It's still got a lovely rolling gait on the motorway where it settles down nicely and it's particularly impressive on those roads where the edges have started to fall away and disintegrate - it soaks them up and keeps tyre in contact with the surface really well - the car behaves like it has a properly developed and expensive suspension set-up (the level of damping and body control is right up there with the KW V3 coilovers I fitted to the AMG).
Not surprising really because the suspension is pretty 'trick'.....it has strengthened and forged suspension uprights, forged aluminium steering knuckles and it's even got Bilstein-branded dampers which is extremely unusual in a factory-spec car....
I'm in no doubt that all these features add up to that incredible 'mid-corner bump' experience but the quality of damping, body control and sheer solidity as it goes over any surface is outrageously good. It's hard to describe anymore but it's almost the
opposite of brittle...for instance, my memory of driving a GT-R is of a brittle ride which made me cringe as it went over rough surfaces (probably more to do with hearing the interior fittings buzzing away!)...this has a feeling of robustness about it.
So, it's fair to say that dynamically this car is perfect for real roads and that it has impressed me so much after experiencing such cars like the M3 and 911 (and GT-R if a 1-hour drive counts?) is a great start. What of the rest of it?
Sound
I may as well move on to what is going to be a very controversial subject....
sound! I will go on record now and say that this car is the best sounding car I've had :confused0068: Yep, thats even better than the AMG!
I know a lot of people would've loved the sound of the Maserati and yes, it did excite me at first. However, after a few weeks it reminded me of a Corsa with a big-bore....you couldn't hear any of the V8 as it was all just 'worst noise and I began to prefer it in normal 'quiet' mode to just hear the V8! No, the AMG with it's spitfire like warble and sounding like a very angry God was always my favourite.
My XKR, with it's optional sports exhaust (again, as fitted to the XKR-S....indeed, the thing is an XKR-S but with 40hp less, no carbon bodykit and £10K cheaper) is like a more raspy AMG. It's not as loud on start up but, when you're driving it sounds like God gargling (I think), it's pops on the overrun and it just begs you to rev harder (all this and I've not taken it over 5k rpm yet!). The pipes also look great - unlike the XFR, they're quite big and point slightly upwards so look rather like 4 cannons ready to fire!
See here....
Here's a little sound clip too but regrettably the car won't allow you to rev beyond 3.5k rpm in neutral/park so you don't get the full 'gurgle' effect
http://youtu.be/tKGqhu-MpEM
Performance
I don't have a lot different to say on this as it's very much the same as the one I test drove and commented on previously. Power is instant and builds nicely, it feels very fast (noticeably more so than the XFR) and is the only car other than the 911 Turbo, GT-R and to a degree, BMW M6 that gives you that proper relentless push-in-the-back feel when accelerating.
Indeed, anymore power and I'd probably be in trouble because after 2 days, I nearly ended up in a canal! :cry: Accelerating on a slightly damp surface with about half throttle and going through just 3.5k rpm, the backend nearly overtook the front and pointed me slightly towards the barrier of the canal bridge I was going over
I wasn't going
that quick (I'd only left a set of lights about 50m back) but given the car had only done 90 miles, it's possible the tyres weren't properly scrubbed in. Thank the Lord above for stability control which again, on this dynamic pack version is a lot looser and probably shows how much I can rely on it
The gearbox is good if nothing majorly different to the best auto-boxes I've had before...it's the typical ZF 6-speeder so is about as smooth as you can get and again, the dynamic pack has a slightly different gearbox software so it's got a faster, more obvious gear-change quality. It's not DCT-quick but it's not that much slower that it bothers me and is infinitely preferably to any single-clutch paddle shift (although I would have a DCT 'box given the choice).
Looks
Not much to say here as you can make your own mind up from the pictures but, with the 'speed pack' fitted (which gives it the bodykit and rear diffuser) and the stance afforded by the slightly lowered suspension, it looks incredible.
I've never known a car that has such an aggressive wheel offset - they're 11" wide and they sit so well in the arches
The suspension set up on this one also sits the car 10mm lower than normal so it just looks 'phat'! :lol: Look at these angles to see what I'm talking about...
Oh, the paintwork on this car is spot-on....unlike nearly all BMW's I've had, theres no orange peel whatsoever so no need for this one to be wet-sanded to give a smooth finish! I've just got to try and keep the light swirls that black cars seem to easily pick up even when being hand washed at bay!
Most of the interior is covered in either leather or alcantara (the headlining is particularly plush), the trim is aluminium and piano black and it's properly solid....when you push on the panels theres no give, no creaking and it's so tight on the move.
The detailing is lovely too....all the buttons on the dash have a nice soft rubber feel and even the seat adjusters look special with their chrome and piano black detailing.....
The leather feels lovely, it's smells incredible and the black/red colour scheme is so me. I was actually prepared to break all rules on this car and get a black interior (it suits the car!) to the point that, when I got offered this colour, I wasn't so sure - which is very unusual for me. I'm glad I followed my tastes because it just looks so special when you open the door!
It's got a great driving position with the most adjustable seats I've ever experienced (well, along with my XFR which had the same)....for instance, very few cars allow the entire seat bases to move up, down, forward and back independently of the backrest. The seats are very low and it allows a great 'legs-straight-out, arms-bent' driving position. It's not so great in the back though....
Finally, it's a great place to sit on the motorway - good job, as thats where it'll spend most of it's time (and one of the main reasons why, to-date, I have dismissed the GT-R which has a ride thats just too busy for my liking as a daily drive). The XKR is refined with very little wind noise and it has the joint-best factory-fit stereo I've heard (the other was the Bowers & Wilkins in the XFR)...if I was being really fussy, I'd say maybe the XFR had better acoustics (the XKR generates more road noise) which made it's stereo sound a bit bassier.
So, I'm pretty confident this car is good enough and has enough to keep me entertained for many months (years?? :lol
....I can honestly say that I reckon it's the best thing I've driven and would even seriously question whether I currently hanker after cars that are out of my reach (such as the SLS AMG, which is my current favourite 'too-expensive-to-buy----but-could-do-one-day' car)....I can't say I do at the minute because I don't think I'd get much more pleasure out of something else.
I've certainly never had a car before where I don't dislike a single thing....not one thing!
I'm going to try and actually drive this car LESS than what I've done with previous cars. I can see me using our work pool car and our Mini a lot more so that way, the XKR continues to be an event when I drive it! I guess time will tell......
