I think it very frustrating that if the battery does not have a decent charge we get really frightening, intimidating messages. I would much prefer a more factual alert and no doubt Television did mean 'measure', I'm terrible at bad spelling and leaving out parts of words.
The sun is shining, the birds are singing and so far it's a beautiful day.
:bannana:
Regards
John
This problem with low batteries is getting more and more an issue, it is not so much the charge , it is the fact that we have many batteries now going partial short circuit on one cell, this lowers the standing voltage to under 11.75 volt.
Under this condition the running voltage is pulled down by the battery, this also reduces the charge rate, as can be seen by Ohms law.
This year the amount of post that I have answered has increased with cars stuck in first gear to ABS/ESP on, have mainly been bad batteries, people assume that if the starter motor works, then the battery is ok
Before anything comes into me in the electronic line for repair, it is pointless checking anything without knowing that all of the voltages are correct. Any faults with low voltage can be within the power supply itself or a circuit that is pulling too much current.
An easy way to check wiring or a fuse holder is to run a light bulb from the said circuit, making sure that the lamp used is the same wattage as the component under test.
Though all of the things we have run from the car alternator, the initial start up is done via the battery.
Always start with basics, as basics are still the number one reason for most car faults, that is batteries and poor grounds.
I have not used my SL for two weeks, but took it out Friday, within the first mile, ABC fault, SBC fault, just drive for a mile or two, tuurn off, re start and all is well, Two weeks is the near max that a SL will stand without problems due to the battery drain when parked up
