Hi Everyone.
I'm hoping someone can help me with a persistant hot start problem on my 1988 300E, W124 with the M103 gas engine.
I’ve had my car for about 10 years. It has 120,000 Km on it. It is a German model with the adjustable EZL-KAT resistor. The car was built in late 1987. Since I’ve had it it has been difficult to start if I leave it in the sun or park in underground heated parking. Initially it had to be really hot outside or underground for about 2-3 hours. Lately it is getting worse. Starts fine when hot for 15 or 20 minutes but longer than that up to several hours is hard to start.
Car starts well when it is cold, runs fine, never hesitates and gets acceptable fuel economy. It has a very slight random misfire when idling. When warm it idles at about 600 rpm in gear. When starting the car and not touching the gas it runs quickly for a couple of seconds and then slows down to about 1000 rpm (in neutral) until it warms up.
Over the years I’ve replaced and tested several items, not all because of the difficulty starting when hot, some just out of regular maintenance. About the only difference was that when I replaced the injectors, the problem actually got worse but the engine seemed to have better low rpm power.
To try to diagnose the problem I put a light and a switch on the cold start valve. I thought possibly it is engaging when the engine is hot and flooding it. The light comes on at cold temperatures but not hot. These days, about the only way I can get the car to start when hot is to apply power to the cold start valve. This seems quite counter-intuitive, it would be like choking a carbureted car when hot. This will get it to fire and often because I’ve opened the gas pedal a bit, the engine will jump up to 2500 rpm, quite smoothly but then die if I take my foot off the gas. Without engaging the cold start valve, often times the car will fire a bit while cranking but not enough to actually start.
This is a list of what has been done so far
Fuel:
Ignition / electrics:
Years ago a local shop had checked the fuel pressure and did a smoke test looking for vacuum leaks. Both were okay.
I don’t know where else to look. Any help would be appreciated.
An additional question I have, does anyone know the difference between a couple of the jetronic engine computer models?
My car came with a Bosch “0 280 800 206” , aka Mercedes “005 545 57 32”
The cars here in Canada all seem to have a “0 280 800 256”
When I swap in the 0 280 800 256 the car runs about the same except it idles too fast, at about 1200 rpm or 900 rpm in gear, instead of about 600 rpm with my computer. There is no hint of misfire when idling at 900 rpm though.
Thanks very much.
Fuel:
- Replaced Oxygen sensor.
- Set mixture using duty cycle measurement on an oscilloscope.
- Replaced Fuel filter.
- Replaced Change-over valve.
- Replaced Cold start valve.
- Replaced Idle speed control valve hose.
- Tested Idle speed valve for valve’s smooth operation and not sticking using a variable power supply.
- New Bosch Fuel injectors, o-rings and holders.
- Measured the profile of the temperature sensor at various engine temperatures, measures almost exactly the resistances quoted in the Mercedes manual. My temp sensor is the two pin variety.
- Replace fuel pressure regulator.
- Both fuel pumps are working and quite quiet.
- Tried swapping Jetronic engine computers, although the one I swapped out was a slightly different number. No difference in how the car ran or started except it idled too fast with other computer.
- New Coil.
- New Sparkplugs (Denso non-resistor).
- New Distributor cap and rotor.
- Replaced OVP relay.
- Swapped EZL ignition control module.
- Measured Crank position sensor as 800 ohms cold.
- Measured resistances of the EZL-KAT plug, all are on spec.
- Used spark tester to measure spark voltage. It was higher than what the meter could measure
Thanks very much.
