- Jan 21, 2005
- Location
- Mittel England
- Smart ForFour AMG Black Series Night Edition Premium Plus 125 Powered by Brabus
If I moved 12 meters from the middle of the house I’d be in the neighbours bedroomThe UFH manifolds are in a different part of the house around 12 metres away from the plant room. I’ll post a photo of the cylinder and piper in a moment.
The pumps will kick out some heat (and maybe a bit from the two expansion vessels as well ?).Here’s the plant room, the pipes seem reasonably well insulated.
When the heating is on I’ll see if I can work out where the heat is coming from.
That’s really nice and tidy.Here’s the plant room, the pipes seem reasonably well insulated.
The other thing I thought of doing is drilling a line of small holes near the top edge within the room and injecting expanding foam but I chickened out of the idea in case the foam pushed the plaster board off the wall.
That’s what the estate agent called it. Airing cupboard didn’t seem right either. It’s where the controls units live for other stuff like security, ventilation system, etc.That’s really nice and tidy.
Calling it a plant room is a bit Surrey though
ps, I think there might be a couple of no-no’s there. I’ll let you I know.
Those are brilliant prices - well done for getting on those tarrifs!Electricity
Product name Exclusive Energy Oct 2023v3 Product type Fixed Product end date 31 October 2023 Rate (including VAT) Any time 25.59p per kWh Standing charge 22.40p per day
GAS
Product name Exclusive Energy Oct 2023v3 Product type Fixed Product end date 31 October 2023 Rate (including VAT) Any time 5.31p per kWh Standing charge 24.75p per day
If I include the £66 support fom the Tories, I am currently paying £15.43/ month for gas and sparks.We pay £81.43/month on a fixed contract till October 2023 for gas and sparks, Currently about £85 in credit.
2 bed bungalow in windy Lincs. Combi boiler Gas hob leccy oven. We do not heat the bedrooms, keep doors closed and switch off lights etc when not needed. All standby appliances switched off overnight.
Maybe a useful point of reference: a senior colleague has a large house with indoor swimming pool and has just seen the gas bill top well over £1000 a month under the new price cap.
My goodness that’s incredible.If I include the £66 support fom the Tories, I am currently paying £15.43/ month for gas and sparks.
You may be surprised! In Barbados, I was paying over $100 a month for water. When they changed the meter, it went down to $25. Meters sometimes fail, my gas meter here failed to register any usage whatsoever, which resulted in an interesting conversation with BG!The engineer is here to replace the meters. He’s baffled as to why it’s costing so much. Let’s see if it changes with the new meters installed - long shot but you never know.
He’s well into his cars too so we’ve just had a good chat. Incredible how a lump of metal, glass, plastic and rubber can bring people together in the way that it does.
East west Solar may actually be a better solution than S. You’ll get power for longer in the day. The peak will be lower but quite often you can’t use all the power at peak anyway. You just need to have two inputs to the inverter to separate the east from west -common.It's frustrating to know that given properly built houses we could use very little energy.
For existing housing stock it feels hopeless to insulate them to a high standard. I stressed it to our architect and the boss of the builders who did our extension and refurb but the guys actually doing the work just don't get it.
We had our roof replaced as part of the job and I was battling with five roofers and two joiners to get insulation into the eaves (only accessible with the roof off) properly while they were just anxious to get the membrane on so it was water tight. It's also become appararent that where dot+dab plasterboard was used the builders haven't sealed the edges - drill a hole in it and a gale force wind comes out. There's a phenomenon called 'the plasterboard tent' and I'm living in one.
I know it's still highly debatable whether solar panels and battery storage are worth it now and I'd dismissed them for our house as the roof surfaces face due east and west. However our 'lean to' extension is due south and I'm annoyed I didn't think of integrating panels into it (and the architect didn't suggest them either). Stuff like this should be almost mandatory unless there's a good reason not to fit them.
Enjoy while it lasts , my fixed tariff ran out just in time for the ky jelly to arrive off eBay.If I include the £66 support fom the Tories, I am currently paying £15.43/ month for gas and sparks.
I have vast stocks laid up in anticipation!Enjoy while it lasts , my fixed tariff ran out just in time for the ky jelly to arrive off eBay.
It’s very dark and very coldMy goodness that’s incredible.
