Donza
- Oct 5, 2007
Almost every car I have ever had has had a tyre pressure chart which shows the pressure for all tyre combinations that the car could possibly come with from the factory. It usually meant as diameters increased & profiles became lower, the pressure increased accordingly.
Mercedes appear to be different, because they only list the tyre size the car left the factory with and its pressure range. The same car with different tyre sizes leaves the factory with different plates showing the pressures.
A few on this forum will tell you the pressure is the same whatever tyre size you have, television was the biggest culprit & in my opinion this information is simply wrong. If you have a larger diameter, lower profile tyre than stated inside the fuel lid, I would increase the pressure by a couple of PSI & see how it feels.
Russ
Many thanks for your post.
This is one of the reasons why i like this board so much. Such great knowledge amongst seasoned Mercedes Drivers.
I took heed of everyones viewpoint, and thus far i have decided to go with 36 PSi in all four tyres.
The real reason i asked for the correct PSi was that i have never driven a car with 19's on. The last thing i wanted was to be driving on alloys with barely any cushion.
