Story a couple weeks ago oil overfull warning came on, next day change oil stick in 7 litres level 1/4 inch below max mark, check a few times okay same level, then it started to get higher
Using no coolant, pas oil level correct, got to check atf but pretty certain no direct link to engine sump.
Oil looks and smells just like any other petrol engine oil.
Was thinking fuel in the oil but difficult to smell, also as injectors go into inlet manifold and engine runs and idles smooth does it usual mpg has made me doubt this route.
Last idea was the charcoal canister set up ie useing engine vacuum to pull fumes out of fuel tank so saving the enviroment, maybe this has gone wrong and is pulling fuel up? but again this is piped up to the inlet manifold.
Charcoal solenoid valve losated on the pass inner wing is quite often clicking all the time.
Any ideas especially ref the solenoid valve?
Got to go dinner is served:bannana:
Lynall
Lynall
