This one is supposed to be really good!
Which ones do you think are better then? As I am considering one at the moment. I do like its small size though.I have one of those - it was ok but there are much bettter ones for the price.
Sorry the Corsa driver is at fault - crossed a solid white line......
As for the merging. Looked fine to me.
You do realise that the van had right of way
You and the Corsa both in the wrong, Transit just plodding on minding his own business, then see's you and probably had to brake to allow you to cut him up. Corsa panicked after realising he/she was going to miss the exit and cut across solid lines
3. Joining the motorway (259)
259
Joining the motorway. When you join the motorway you will normally approach it from a road on the left (a slip road) or from an adjoining motorway. You should
- give priority to traffic already on the motorway
- check the traffic on the motorway and match your speed to fit safely into the traffic flow in the left-hand lane
- not cross solid white lines that separate lanes or use the hard shoulder
- stay on the slip road if it continues as an extra lane on the motorway
- remain in the left-hand lane long enough to adjust to the speed of traffic before considering overtaking.
Maybe to to compensate for the fact that the gap infront of the van had disappeared as a result of having to brake for the Corsa?Why did the Idiot in the car with the camera nearly follow the Corsa over the hatched area?
