W124 start failure (E220, HFM)
I'm trying to chase down the same problem ... changing fuel filter didn't help (thought a blocked/fouled filter was causing the fuel pump to stop early), beating the fuel pump relay hasn't help - thanks for the tip about the OVP relay / battery voltage guys, that will be tomorrow's entertainment.
Does anyone know if there's a *factory* manual for the injection system anywhere? I got one for the LandRover EFi system and it saved me a fortune ... they usually give test flowcharts and processes which will help with testing sensors (temp, airflow, crank pos, lambda ... testing these by swapout can be expensive without a "spare car" to swap bits in and out of)
Interestingly, my car is 1995/96 as well - it does look very like an electrical failure related to age as a couple of folks have mentioned.
