- Oct 15, 2008
- wme451 a124 r129 s211 r230
Any ideas please? Someone I know has a 320 SL, which has had the gearbox rebuilt. A couple of times, changing from D to R, the box has remained in neutral. A diagnostic check suggested a CAN problem, and could not be cleared. The following readout was printed:
Motor Electronics 2
P1681-154 Crash signal implausable current and stored
P1747-062 CAN fault not defined
ETC - Electronic transmission control
97 Test fault (ignore) stored
136 CAN comminication with control unit instrument cluster is sporadically disturbed stored
ICM- Instrument cluster with maintenance interval display
B1040 Fault in CAN communication with control unit MR engine control stored
B1041 Fault in CAN communication with control unit Traction systems stored
B1042 Fault in CAN communication with control unit BAS brake assist
B1745 The serial interface K1 of control module AAC to control module instrument cluster has -- + stored
B1755-001 The serial interface K2 of control module AAC to control module instrument cluster has -- + stored
B1755-000 The serial interface K1 of control module AAC to control module instrument cluster has -- - stored
Any suggestions gratefully received. Thanks in advance!
Motor Electronics 2
