GreetMe
- Feb 15, 2012
- Mercedes-Benz A45 AMG
Looking at them both I'd have said the C63 was wider but I can't find a definitive answer online. Some sites list the Merc as a few cm narrower (199.7cm vs. 202.7cm); others list it as slightly wider (203.1cm vs. 202.7cm). I'm assuming this is because some lists include the mirrors in the overall width and some don't.
The reason I ask is that my Golf *just* fits through the stupidly-intrusive door arms on my garage. If I get the approach wrong I have to fold the mirrors in (the space opens up quite a bit inside so they can be unfolded again as soon as I'm through the door).
Also, with the mirrors folded in, from some angles it looks like the C63's widest point might be the top of the front wheel arches. Is that true or is it just a trick of the lens?
I hope you can see where I'm going with this: if the C63 is wider than the Golf with the mirrors folded in then I'm going to have a nasty shock when I finally bring one home... :fail
