Perhaps the RHD vehicles have a different type of clutch? There are differences between models, see the Breakaway Clutches part of this description (though it is from a few years ago): Mercedes-Benz Four-Wheel-Drive In-Depth Look | eMercedesBenz
JohnM said:Perhaps the RHD vehicles have a different type of clutch? There are differences between models, see the Breakaway Clutches part of this description (though it is from a few years ago): Mercedes-Benz Four-Wheel-Drive In-Depth Look | eMercedesBenz
I see that all LHD GLC's have a multi plate clutch in the transfer box.
Could it be that RHD's have only a single plate due to space issues? In other words the only way they could make a RHD 'GLK'.
When I drove a C43, I was bothered by the extra wide tunnel pushing my left leg too far right.
2WD and a set of winter tyres would be a lot simpler and cheaper.
As in the C-Class though there seems to be some clunkiness in the application of the system. In the C43 we noticed some chuntering on full lock and at low speeds, such as pulling out of parking spaces. In the E43 it's arguably even more noticeable, the front wheels 'skipping' as if there's some transmission wind or a locked diff somewhere in the system. Interestingly the Porsche Panamera 4 S we've got in at the moment does the same thing, albeit to a lesser extent and Mercedes is promising to get back to us since raising the issue
Bluegnomes said:This seems like a characteristic across the 4matic range?
My Audi S3 didn't do it, my BMW 3 series x-drive didn't do it, Volvo XC60 didn't do it so why can't MB engineer their cars not to do it?
Just to rock my theory a little when it comes to Porsche and MB making RHD cars with 'Characteristics' that may not please all drivers its worth remembering that their main market is North America and Europe which obviously have LHD so this particular problem is non-existent in these places otherwise it would no doubt have been sorted by now.I was just about to post a link to the issue raised on PH but, as usual, I'm behind the times.
Taken from All Wheel Drive Explained | awd cars, 4x4 vehicles, 4wd trucks, 4motion, quattro, xDrive, SH-AWD, Haldex, Torsen, wiki - How it works
Assuming that the "differential lock" function on the same axle is taken care of by Mercedes usual selective braking via the antilock/stability control system then cross axle transmission wind up should not be a problem. On the front axle there might be steering scrub if true ackerman steering is not present [ i.e. each front steering wheel to be at a slightly different angle in order to trace out a slightly different curve radius]---- I guess when the wheel is driven this might present as a series jumps or clonks????
However- the front and rear wheels also have trace out a different curve radius. Again wheels on the same rear axle present no problem with an open diff.
Which leaves us with the prime candidate for transmission wind up [ front to rear- not side to side!] IF!!! the centre differential is locked or close enough to locked meaning the front and rear wheels can't rotate at sufficiently different speeds while necessarily tracing out their different radius curves.
My theory is that some sort of effect like this may be exacerbated by the 39/61 torque split if indeed LHD cars don't suffer from this with their 45/55 split ?
While for driving on grippy pavement at slow manoeuvering speed at full lock it might be useful to program the centre diff to disengage at high steering angles its possible to envisage this as a situation where full 4WD might be very advantagous when trying to manoeuvre/ start off on very slippery /snowy conditions. Its perhaps the sort of ability lots of owners would expect ---nay demand from their 4WD vehicle. In the old days all these differential locking actions were manually selected by the driver as appropriate to conditions but now its all automatic meaning perhaps there has to be compromise somewhere.
or something like that.![]()
