Teego
I just carry my key on a lanyard around my neck.
I’m so used to Keyless Go you forget
Just tried on my GL and it’s impossible to lock the keys in.
Vehicle locked - if you open the tailgate via the fob or the handle it opens.
Leave key inside, press the lock button and it won’t attempt to close as it knows the key is in the wrong place.
Press the usual close button instead, tailgate closes but won’t lock the key inside. Sets the alarm anyway and the alarm goes off if you open the tailgate later on (obviously as soon as you press the key buttons the alarm is silenced)
Possibly an overlooked advantage of the Keyless Go system - not only can you not lock the keys inside accidentally, but you’re less likely to do so as you have no need to take the key out of your pocket (and sorry it’s of no help to the OP’s circumstance)
Too bloody right!You'll have to make sure Julie takes a spare next time , be cheaper![]()
Yep , I could also do that with my W140 .I could do that with both the S204 and the SLK. Luckily we have 2 keys for both, and after a similar escapade with our 968 coupe some years ago (and an earlier one when the wife did exactly that with a Citroen estate) whenever we go out, wife always takes "her" key in her handbag!
Thanks everybody, I thought my Green Flag membership had lapsed but checked and I still have two weeks left.
I gave them a ring and they said they will be with me before seven this evening.
Fingers crossed. Will report back later. john.
I think you should play this song to your wife as a hint what you need as your next birthday giftUpdate. Green Flag said the car was deadlocked. He got inside with a hook and pulled the drivers door lever but no joy.
Auto locksmith coming Monday morning to hopefully get in. £65 plus the old vodka and tonic.
Will report back. John.
Could he not have hooked the keys out from the rear passenger door??Update. Green Flag said the car was deadlocked. He got inside with a hook and pulled the drivers door lever but no joy.
Of an estate??Keys were on the boot floor
Of an estate??
That’s why I thought that with a bit of patience the bloke could’ve hooked onto them with his gadgets.“Hi all my wife has locked our car with the keys inside. Its a 2011 w204 estate, I can see the keys on the boot floor through the tailgate window.”
I understand now. I thought the guy could go in over the top of the door frame (weakest point).If the Doors are "Dead Locked" there is no space to "Hook and Remove" the keys!
