isobars
- Dec 20, 2009
- Location
- Portugal, Belgium + Lancashire
- 300SD'79, E300TD '95, 300TDT '82, 280CE '84, 250L '84, 300SEL LPG '91, 300D '80, 300CE '91, 300E '89
Hi All,
After having spent many, many hours on a steep learning curve I finally dismounted the water pump, only to be faced with a 1032001452 Water Pump Drain Tube which will NOT budge.
Is there a later version of this pump so that I can just cut this pesky pipe - which is not only almost welded-in, but perhaps clips to the block in the very bowels.
They do say that they started with the W pump and built around it, what a terrible job.
Thanks for any input.
Cheers,
Paul
Cheers,
Paul
