BenzedUP
Not seen any MB gain anything on de-cat, if anything they loose hp as you loose back pressure... so I am told.
As mentioned above I think most people just remove the secondary cats and resonators rather than a full de-cat.Not seen any MB gain anything on de-cat, if anything they loose hp as you loose back pressure... so I am told.
Ive been thinking about getting a map... my cl55 has the secondary cats and resonators removed and a pair of k&n's.... I wonder what gains Id get from a map and if it would actually be noticeable!
Cerbera said:As mentioned above I think most people just remove the secondary cats and resonators rather than a full de-cat.
Sounds good Andy!
How much did you pay if you don't mind me asking?
Does anyone know if there's any truth in what Cerbera said about the ECU resetting itself?
Cheers!
To be honest I can,t remember as I paid it in two installments and then took the option of the live data mapping with the Dyno runs which again was extra.
At least you got a reading on the rolling road with your car Andy, couldn't with mine
Why?
The ESP kept cutting in even when it was switched off me, Jerry and a few others tried different things but could not get the ESP off. i.e. putting a fault into the ESP by disconnecting the control unit, the stop lamp switch etc but no luck
Ah sucks!
With your E55 lump, headers and remap you must be making 380-390bhp and well over 400 lb ft torque easy. Sounds good to me!
Got to be mate, the torque of it now is amazing :bannana:
Damn, you'll have to take me for a spin some time.
Don't get me wrong my stock (catless) 55 is quick but doesn't give me the shock and awe it used to hence looking at power mods! I wouldn't actually mind a slightly shorter final drive as that would really liven things up!
Ah sucks!
On a separate note, has anyone gotten close to 450bhp with an N/A 5.4?
Anytime mate, it drives like a different car to when it was a 43
The ability to light up the rear wheels off of a roundabout or bend in the road is unreal, only downside is tyre wear
You need an LSD, my 32 has one and that thing hardly ever spins compared to the 55
One is on my to-do list for sure, but I do enjoy sideways drifting
