nb_racing
Hi all,
In theory, can you bolt a manual box, from say a 170 SLK320 (112 engine), onto a 113 V8?
The 112 and 113 are essentailly the same. So does anyone know for sure if the bolt pattern is the same?
Also, if a 113 from a 210 E55 was used as a donor engine in a project, can you run it on the standard ecu without the autobox interfacing with it on the CAN bus?
Cheers.
Cheers.
