grober
MB Master
Even with a small block chevy those struts have to go.![Frown :( :(](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f641.png)
before
after
before
![mercules_part_8_01.jpg](http://www.mercules.com/buildimages/part_8/350/mercules_part_8_01.jpg)
after
![mercules_part_10_25.jpg](http://www.modifiedcarforums.com/blogentries/2008/_mercules/part_10/350/mercules_part_10_25.jpg)
I wonder if a custom brace could be fitted over the engine? If MB put one in there must be a reason.
I've found his album - this is helpful too
, so festina lente.
Because of the triangulation effect the struts would have markedly improved the rigidity of the front engine cell. That said it might be argued it was typical of the period Mercedes over-engineering and was not strictly necessary. [ I remember early Ford Consol / Zephyr monocoques similar triangulation bracing till the designers got more experience ]I wonder if a custom brace could be fitted over the engine? If MB put one in there must be a reason.
Triple 40 Webers - £750 for the Webers, all that is then needed is a fabricated manifold and the engine bay can be made to look really lovely. It may not go faster and would eat the fuel a bit more, but it would be fun.
This is the most revealing pic. Imagine the 114/107 crossmember is just behind the sump approx where the No21 is in the M110 section. Now transfer that position to the 103/104 engines and you can see how these engines simply won't drop straight in without major sump mods. The earlier series engines had sumps with the main pan much further forward to clear the big crossmember.
I had to manufacture a steel sump to get the OM606 into the 107. The 606 is essentially the same crankcase as the 104.
Pics later when I get back on the PC.
My feeling is that these American "v8 transplant hotrodders" pay scant attention to the final overall body rigidity
My money is always on a bunch of highly skilled and experienced German engineers with a large budget working for the most quality conscious carmaker of the time over a chap with a hound dog called Robert E Lee and a barn full of moonshine, or indeed Fred in his shed in the West Midlands...
My Allard lacks a lot of structural bracing, apart from the wooden superstructure, the engine is insufficiently braced so when you introduce vibrations as a result of riding the clutch (vital for low speed manoeuvres) the entire car shakes viciously.
Before you actually go down that route, speak to a pro. I'd imagine a set triple carbs won't be anywhere near utilised without a head job, suitable cam and a decent flowing exhaust manifold. May as well fit a modern retro fit electronic ignition system too. Triple (pun intended) your £750.
Bear in mind, for less than or similar money you could have an EFI set up, which would be transferable to another engine at a later date.
Well, the head needs to be converted to run on un-leaded anyway....
I keep forgetting this! It's not something I've ever had to do but will no doubt be costly!
A donor engine starts to look better.
To answer your question, I think the M104 will not run under its own juice without an ECU that has been re-programmed. Certainly my 104 engined estate had numerous issues when one of the ABS wheel sensors went. I'm not sure about the M115 that James suggested - it's a much earlier engine design. I suspect in both cases the problem is not insurmountable.
Can the OM104 be run away from donor on its own management, and when coupled to an auto box? Is this question unanswerable or haven't I asked it often enough yet?
The Webers wouldn't be sized for performance improvements, if two will do the job of the same level of fuelling as the D jet then that is what will go on. They are simply meant as a replacement for the D Jet so I don't spend a lot of time and money getting that running.
Economics will be done to the last penny!
