Charles Morgan
- Feb 2, 2010
- Mercedes 250CE W114, Alfa Romeo GT Coupe 3.2 V6
Returning to the V8, we have established that (ignoring engine bay rigidity) an M116 V8 could be made to fit, but the rear diff from a W126 donor would be too large. Reading the numerous threads elsewhere the W116 V8 diff is the same size as the W114/5, as indeed would an 85 W126.
(Remind me Druk which diff you ended up with in the 107?)
If that is the case then fitting the auto box and making the engine work in a standalone situation are the key factors, with everything else a bit of a bore but doable.
If not, then a small block chevy returns to the frame.
