Mercedes W114 250 Coupe - help!
Like that Grober. Do you know the spec. The only thing I've copped is what looks like early ATS alloys.
the AMG 250/8 wheels- these perhaps?
changed my mind http://www.benzworld.org/forums/sale-wanted-trade-giveaway/2147825-ronal-kleeblatt-wheels.html
Ronal Kleeblatt's??
attachment.php
Took the liberty to edit your picture slightly to make it more legible - hope you don't mind. Can I ask what the book was ?
No worries grober, ISBN 978-3-7688-3494-0, Forty five years of AMG - The story, The cars.
Got a reply from Daimler AND Mobil re Mobil 1 to 229.1, 229.3, SM/SL/SJ/CF there is no known issue with low prosperous or zinc levels with Mobil 1 to 229.1 & 229.3 holding SM/SL/SJ/CF approval as well for the M100 series motors at least. They BOTH said if the oil spec for your engine determined by Daimler is the same as the spec on the back of the pack, then the oil is suitable irrespective if it is SM/SL/SJ/CF as well. Daimler confirmed that 229.1 & 229.3 is correct for the M100 series engines and went on to say this...
"Contrary to your received advice regarding the M104 valve train componentry we have no historical evidence of product issues based on zinc levels."
I've a M104 with 235,000 kms on it - it won't blow smoke on long overruns when subsequently applying throttle - I'm happy and confidant that this advice is correct.
Sorry Charles seem to have temporarily hijacked the thread ---again! Those Kleeblatts would look nice tho.
A welcome little detour!
There are some adorable wheels of the period (shoot me but I can't get excited about Mexican hat ones). I have a set of ATS classics for my BMW02 but they are 13s, those Kleebatts are often seen on period BMWs, while the Chromadora alloys on my Fiat are to die for. Having almost put my back out spending hours trying to shot blast the standard wheels, they are the ones going on the car as they are just timeless.
I'm intrigued by the notion of the V8 engined cars. They are putting out quite decent power and torque, which for the weight of the car must have been quite something.
I saw a W115 220 yesterday in Oxford - some slug of a Citroen C3 prevented me from getting close up (there is something utterly depressing that a 70s small engined MB is being driven more positively than something with more torque and power). It is a very airy shape, very much like the larger W108s, modern as well as classic.
Well, an attempt to recreate the latter using my angle grinder hasn't been particularly successful so I am now aiming for a /8 laundaulette / targa look.
It would have been a really lovely convertible as a series. It even appears to have headlamp wipers (and wheel arch rust - why ever else would you have chrome arch covers!).
The stretch 8.
I saw one of those doing duty as a limo in Northern Cyprus in the early 90s. I imagine it had the 2 litre diesel engine to ensure safe cornering.
The w123 equivalents were very popular in South Kensington when I first moved there - Gulf families found them perfect extended family transport in the summer when they moved over to London to avoid the heat.
Right, I decided to type out the german V8 conversion doc (a bore - dear Mr Gates changing warden to warden every time is a PITA) and whacked it into Google - I have to get a paper done soon. It describes a 117 and is of course for an LHD car. So applicability, umm
Here goes for posterity though - lots of poor google translation and technical terms (and german multi-word words largely untouched).
"The dream of every / 8 driver it is safe to exercise after the start-process of the "babbling" of an 8 cylinder engine. Since there is an excellent MB8 cylinder engine in serial program, it is tempting, those "einzuflanzen" in a W114. But, does it work? To anticipate: Yes!
I report today about a conversion that was once performed Whether the vehicle has a TUV approval was obtained, is another problem. The car described for only with red number!
The mounting position of the motor M117 is hangend easily back and forth to the left obliquely inclined. This is due to the limited power steering (version without capping nut). With a different steering is possibly a correction possible. The lateral mounting position results in essentially of the space for the exhaust monkey with red number!
Engine bearing front 1142230212 (60 shore)
Engine bearing rear WE 24-6 / 68 (45 shore)
2 stuckerdampfer (400N / 400N) was scaled down to the lateral motor store volume by about I l. The oil filters must be installed bent forward and laid the lines to the chain adjuster. In addition, the pressure regulator for the idle adjustment had to be set lower and the dauber located behind the air filter cut off. The air filter russel was angled and gekurzt about 30 mm.
To find a 280E Cooling radiator use, the Oil cooler take off was not completed (connection of course possible). As a fan is a visco-Lufter. Gunstig is the connection of a differential pressure diameter (before / after Oilfilter), as well as an oil-thermometers.
The exhaust monkey were made of sheet steel. The left manifold was ordered to be pulled forward and downward because of the steering. The exhaust pipe system is two (strong pipe 50 x 2) with 2 fully trained sound absorbers.
The regulierwelle the engine was changed with all the levers. Because of the limited Platzverhaltnisse was displaced upward in unaltered regulierwelle on the front wall of the pivot point. For this purpose a Neuses pedal is made of 2 pedals blended series. You return spring was amplified. As transmission en serie bulky 5-speed transmission is used contact pressure with 8000N behind union coupling M240. Switching is done via a gekurzten means lever. The gearbox was exchanger, check the position of the motor abgeandert accordingly. Thus, the joint shaft can rotate with moderate kink angles, was ordered to the joint shaft center bearing to 13mm high set, the rear axle warden highlighted on the rear shelf to 5mm. (Bending angle of less than 1 ° are a major guarantee the durability of the joint shaft discs and prevent brummer).
When translations are centerpieces used with i = 3, i = .46 or 3.69. If you decide for the installation of a 4 gang switching or automatic transmission, would a longer aches with 3.23 better (but joint shaft speed note!). Optimal would be the installation of a medium stuckes with barrier-balancing. The rear axle may otherwise be left unchanged. A big problem-represents the steering - the attachment between the lever was ordered because of the coupling angesstzt lower on the motor to 120mm, under the lever itself be mounted upside down. The ball-point position thus remained the same (important for the lenkgeomtrie). At the front axle itself only verstarkten handlebars were mounted with contractual joint insurance. The starter does not require a change in the driving stool.
The second critical point is the brake: be installed an 8 bremsgerat tandem with the foot lever system had reasons of space 60mm offset to the left. For this was the wheel arch slightly dented (approx 10mm) Because of the windshield wipers died anges and the outlet of the cable Padfoot had the bremsgerat also be transferred to 45mm forward. At the foot lever system were changed ausserem the kupplungsanlenkung (kuppelsweg approx 170mm) and the return spring amplified.
Because of the higher stress beluftete (based on type 107) were fitted brake discs. If necessary, a pressure-reducing valve (hydra search, 30bar) can be installed (for balancing the weight shift to the front). The Tuv had to be satisfied in general with the conversion of the brake system on the model series w107, but there are the axes similar to the W114.
The battery was installed offset (55ah) to the right, where the right-to easily wheel arch had to be dented (max 10 mm). The entire cable set refresh this had to be. Safe use around the water outlet and containers for the injection system was added.
On the body had except for the storage of the LZH (already described) be changed nor the middle tunnel, which was raised from about mid gear and to the joint center storage well to 20mm, then to early jolt bench auslauft on the old high. Presumably are necessary for use of a 4 gear automatic transmission tunnel walls further ments. ON the front long wear were angled slightly only schweissborte.
So, all right, Who only place that has money and a gehorige portions courage can get started. In gesprach a mite TUV engineer was suggested to me that the MOT approval at least nich impossible ware (a residual risk remains, of course, still useable!) The vehicle described exists now not unfortunately. The erfolgversprechenste approach is reflected in our moment in anyway fastest man, who confirmed my photo here, the V8 fits the /8.
That, appears to be a lot of work - and I'm not merely referring to your efforts in typing it for translation.
At a guess you will have to approach each modification in turn and gauge the level of complexity required to achieve the required result as information as to 'how to' is on the sparse side.
Sure you don't want a six?
