Charles Morgan
- Feb 2, 2010
- Mercedes 250CE W114, Alfa Romeo GT Coupe 3.2 V6
Found a W115 pedal box, but will hold off ordering as I'd rather leave the existing system in place (means having to sort a redundant hole in the bulkhead and patch the firewall insulation having only just done it!).
Car is now off the ramp for a period while we await parts and the return of the heater matrix and driveshafts. One thing that is driving the techs potty is that so many parts and fastenings are incomplete from the strip done 20 years ago - anybody doing a project strip the thing in sections and put the fastenings where they came from! Saves an awful lot of problems with putting it all back together. Most are available but it's a bugger having to sort things out half way through as so many are unique. For the next phase I'll be ensuring as much as possible is sourced and labelled beforehand.
Plus of course, things you buy turn out to be wrong - the rear brake hoses, labelled as such, that aren't because they are 15 cm longer than the originals, the centre propshaft bearing (aftermarket) that wouldn't fit the replacement housing (aftermarket) and died in the attempt. JJ doing it is immensely experienced and patient, but 20 minutes here and there to sort out issues like this with non OEM stuff more than eats up the savings - all the OEM stuff has gone straight on.
I'll return to the theme of fastenings later today when I've had my breakfast!
