ML270 CDI W163 coolant light on but coolant level OK...
Mercedes 270CDI Coolant Warning Light & Limp Mode.
Last night I experienced the Coolant Warning Light come on while we were travelling in Edinburgh. It was just before midnight and the warmest day of the year still showing 21 degrees. So I believed it was just a warning for low coolant level. I went into the garage and checked the coolant level and it was fine. The temp was all normal on the gauge so was a bit baffled untill I discovered it was now in limp mode.
This morning I did the usual checks of fuses and found nothing wrong so then into MBClub threads for some assistance.
Discovered the maxi terminal fuse threads regarding blown fuse and the tell tale signs of Heated Seat LED lights flashing but not engaging.
Stripped the connections of the battery and checked the fuse. It looked fine but removed it all and cleaned all the terminals and the fuse and replaced. The problem was still present. The warning light was still illuminated on the dash board and limp mode was still present, not revving above 3000.
So I returned to the MBClub threads and discovered the submissions regarding a hidden fuse that is located under the secured section of the fuse box located under the bonnet.
I removed the usual section of the fuse box. I then loosened five small hex screws that secure the cover to access the area behind the normally accessed fuse box area.
I noted the small fuse holder and a RED 10Amp fuse located on a right and side of concealed fuse box secured by a slide mount.
I checked the fuse and as stated in previous threads it was blown. I replaced with a new 10Amp fuse and all was back to normal.
Limp mode was now cancelled and the dash board orange coolant level radiator symbol light was now off. Heated seats operation lights now back to normal. The complete job checking and cleaning the terminal maxi fuse was about fifteen minutes. The job of replacing the hidden fuse behind the fuse box FIVE minutes. Car now back to normal and driving as normal.
We have had it seven years and the second owner and it has covered 99000 miles exactly.
What a great original thread this was and saved me lots of problems as we are just about to trade the car in. I cant thank the people who submit these threads enough for their help. Thanks. Kev.
hi guys,I've been having a simular problem with my 2002 ml270, coolant light stays on but lvl is fine. I've replaced said 10 amp fuse. light was off at start then came back on.
temp stays at a constant 80,heated seats work. No limp mode tHo.
can I still run motor without causing damage? as it runs fine
Fixed my coolant light by opening plastic cowl over the fuse box in the engine inside near the ECU is a ten amp fuse, various garages said pressure test required or new fan or replace coolant tank with integral sensor bloody rip off garages. TEN AMP FUSE replaced now fixed.
It’s on the right side of engine!
My lights back need to replace FAN CONTROL UNIT or buy fan with f c u
This I’m told is very common on modern mercs
Well here we are in 2022 and this thread is still helping people. Yesterday on the way home from hospital the low coolant light came on. Only 5 minutes from home so finished the journey . Checked the forums
Today , found the hidden fuse solution and it has cured the problem . Thank you to everyone dating back to 2012 for the information provided.
Hi again, After changing the fuse and the problem being solved , the low
Coolant warning light is now back on . When I change the fuse now it blows as soon as I switch the ignition on. The 10a fuse on the battery hasn’t been changed as I can’t get hold of one. Phoned 3 dealers and the fuse is on back order everywhere.
What can be causing the fuse to blow ? Thanks in advance
Where is the 10 amp fuse can someone send me a photo please? And the fuse on the battery what does this look like please 🙏🏾 I'm not good with cars but I want to try sort myself before I spend a fortune at the garage. I have the same coolant light grated seats issue 🙏🏾 I'm a very visual aid person so photos help
