That is scary! I must admit that I work on the principle of 'if you want a job doing properly, do it yourself'.
I have also learnt that most 211 have short wheel bolts and 221/ML have much longer ones. Quite a few non Mercedes wheels require a bolt length in between this length. Too long and the bolt can catch on the insides of the hub and/or leave the wheel loose, too short and you are in real danger of the wheel coming off.
Make sure the bolts stick 20mm through the back of the wheel!
Good save!
Good save!
