Barachello
- Jun 6, 2013
- C270 cdi
The other day I received an indication on the dash display that one of my number plate bulbs (left side) was defective.
I have tried changing the left bulb, with no change. So I changed the right one as well, after cleaning both contacts, in both sides.
I then checked the wiring going to the left bulb and tracked it back to the rear sam. Disconnected, cleaned and reconnected all connections.
Still no joy.
THe left side bulb is flashing every couple of seconds.
Has anyone else had the same problem, and found a solution ?
(I have tried a search, but there seems to be a problem with the search box ???)
Still no joy.
