Original 55K Oil Cooler Mount Brackets - Needed
simon1966
Surrey
219 Vito Sport Crew Van
Hi All
This is a bit of a long shot but does anyone have any spare brackets off their 55K oil coolers where they mount onto the u/s of the Heat Exchanger?
There are 2 different brackets, one is a single part bracket, the other is 2 part. I have a new Eurocharged Heat Exchanger but my 2 part bracket is missing and I want to re-mount the oil cooler as original.
Couple of pics of what I need. 2 part bracket on l/h end (this isn't my HE as this is on a CLS but same thing).
Any help much appreciated, before I go down the route of getting something made to suit.
Cheers Simon
Hi simon
Spotted this thread on the forum across the pond, tech drawings of parts may come in handy to track down what you need.
Oil cooler line confusion - MBWorld.org Forums
ginger
Hi Ginger
Thanks - that's helpful. Looking at one of those diagrams it looks like one section of the 2 part bracket is probably available (part no. 280). Trouble is the other part would be part of the standard HE as its riveted to the u/s of it.
So would that mean your after a scrap secondhand HE to rob the part from?
I reckon mate, although looking at it the part that is fitted to the u/s of the HE is just a plate with some threaded studs so I could probably make something similar if I can get part no.280 from MB.
I will be having my HE upgraded over the next few weeks, so wasnt sure if the original mounting points or what fittings were re-used, but if its surplus i can send it your way. (Eurocharged charge cooler)
Old ones are normally reused to mount the new he
There was some corrosion where the 2 part bracket was fixed on my original HE and I think as a consequence it was probably discarded, although I wish it hadn't been!
I have just been to my local MB dealer and they are ordering 1 part of the 2 bracket in for me from Germany (part no. 280 on the mb world link). I will still be short of the other part of the bracket though that would have been riveted to the HE. Therefore I still need this bit or will have to get something made up. Trouble is it has 2 welded threaded studs on it to receive the other part so its a bit of a pain!
