Just an update.
Brabus spend alot of money tuning Mercedes. They are not just a random company that tune all manufacturers, just MB. I would not for an instance believe that a chip will cause 10mpg difference; if it did i'm sure a huge fuss would be kicked up.
If you buy a chip on ebay for a fiver, or a piggy back box then yes, your mpg will be worse. 10mpg worse? I doubt.
A proper ECU remap or box will do what it says. It will give you more performance at a slight decrease in economy, but at cruising speeds it is normally better on fuel. How do i know? Well i've chipped every diesel i've owned and haven't complained about economy till now.
Yes there are downsides to chipping a diesel. Injectors fail more commonly, gearboxes die relatively easily and any turbo pipe that is beginning to fail will leak.
Now i beleive i have fixed the car. I recently changed the instrument cluster in the car, i had a pixel fault so bought one from a breaker. it was removed from a E320 CDI same year as mine so i presumed its a straight swap over. The only difference i found is that when you fill the tank my old cluster said 15.4 gallons and the new one said 14.2 gallons when full. didn't really think anything of it till i spoke to Ollie at PCS.
Now apparently the coding is very important on these clusters, even though its removed from the similar car it may be different.
SO this morning i swapped the clusters back round, filled the tank to the brim, drove 86 miles of mixed town and motorway driving and back to the same petrol station, same pump so i can have an accurate reading. The trip computer showed 35.2mpg average since refill, i filled up 10 litres dead. I make that to 38.2 mpg, so better than the trip meter.
Has anyone ever heard of this problem?? I know its right as the same journey was done yesterday but took nearly 20 litres
Needless to say the old cluster is back in the car till i can find out about coding it correctly.
Now i wouldn't have thought a cluster could be important to fuelling side of things, does anyone knwo what it exactly controls?
