Power steering filter
frier
essex
mercedes 320 s class 2008
320 s class 2008 need help wear is powersteering filter
Usually in the bottom of the reservoir where you put the fluid in...
Thanks it looks sealed in reservor havent taken off yet mine square reservor on s class
If its the square plastic reservoir then you replace the whole thing as the filter is cast into it. I do not believe it is even a maintenance item these days.
