Questions for CTEK battery charger owners
Mr. B
I have just taken delivery of CTEK battery charger MXS 3.6 and I have a couple of questions, which will be simple to all of you chaps.
I own a C63 AMG (no comments please).
I want to charge the battery in situ still attached to the veh.
I am trying to work out which clamp to attach to the chassis, if any and which to attach to the battery terminals ?
I was going to attach both to the battery terminals but the instructions suggest if the battery is left in situ I should attach the -ve clamp to the chassis.
It also suggests that if the veh has a +pos earthed battery then the red clamp should be attached to the chassis.
I'm a little confused or should that read thick ?
Next question is regarding the charger itself. Do any of you charge the battery fitted to the C63 on the cold weather program as per instructions.
Thanks.
Job sorted !!!!!!!!!!!!!!!
