Zonergem
- Aug 31, 2016
- 2015 Audi A6 C7 Avant (daily), 1992 R129 500SL (precioussss), 1989 C124 300CE (project)
Late last year I bought my R129 - a nice clean 74000 mile 1992-registered 500SL - which is about to receive a stem-to-stern refresh - fluids, filters, bushes, shocks, steering, mounts, HT system, the lot.
My roof is in good working order but I know I need to flush and replace my hydraulic fluid. Two litres of Febi 02615 turned up the other day. The car was actually built in July 1991 and first registered in May 1992, so the seals and cylinders are closing in on their 26th birthday. I'm a little worried the new fluid might cause the seals to let go sooner rather than later.
Since I'm about to try and make the car good for the next ten years at least do you think it's worth pre-emptively having the cylinders taken out and shipped off to Top Hydraulics in the USA for a rebuild? The cost would be at least 500 GBP plus postage and labour to remove the cylinders, but then at least the job would be done.
The Top Hydraulics website warns "The original seals in the hydraulic cylinders, aka rams or actuators, will eventually fail in every R129" which may be true (the heat death of the universe will *eventually* take care of things) but what would you do? Put it on the back-burner and deal with the problem if it happens, or swallow the cost for the sake of peace of mind?
