Hi All,
About 4 months ago, I noticed smoke coming out of the front of my ML270CDI. I opened the bonnet, and notice Diesel pouring out of the fuel pump, all over the belts etc.
I immedietly shut off the engine, then removed the engine cover for a closer inspection, and noticed that 'Black Death' had started to form around injector 1. I got the car recovered and had the injector seal fixed by a Mercedes Benz specialist, and also asked them to look into the leak from the fuel pump at the front
They successfully fixed the leaking injector, but could not recreate the diesel leak, and it has not re-occured in the last 4-5k miles. I have however noticed that when it is very cold, it can take a bit of time to start. Googling these symptoms has revealed that perished o-rings on these pipes can cause this, which makes sense when considering the one off diesel leak. I would like to try and replace these myself (I am a relatively competent mechanic, having restored a number of
old volkswagens). I do however have a few questions before I start...
1.Is there any way that the blown injector seal cold have caused the leak / blown seals on the pump?
2.How difficult is it to replace the o-rings.
3.How many will I need and is there anywhere to buy them online, or does anyone have the part number?
4.Will I need to re-pressurise the fuel system?
Any help really appreciated
Geoff
Geoff
